Once again, Audacity has decided to not record. I don't know if a recent update caused this problem or not but I had been recording successfully for the past few months. As of today, no recording capability using versions 1.3.7 or 1.3.9. No activity on the VU meters indicating signal input of any kind. System audio of streaming videos, Internet audio/video, DVD's, CD's, etc. all work fine so it appears that system level sound is working as expected.
I can record just fine using Sound Recorder so the recording signal appears to be available at a system level. I have no problem using Audacity for opening, editing, saving any of the audio files; I just can't record.... I use Audacity quite a lot for recording/editing and, when it works in ubuntu, it's great! When it doesn't work, not so great...this is one of the few apps that I use on a regular basis and the recording aspect is as important as the editing capability...(hate to say it, but it has always worked just fine for me on XP)...I can't see any need to run WIne or a virtual install of XP or a dual boot system when I know that Audacity will work just fine on ubuntu or Linux in general if I can just get it configured correctly (again).
I have read and applied a bunch of "Audacity/sound system related fixes" and hacked around with Pulse Audio, Esound, OSS, Alsa, etc. from the ubuntu forums (and other Linux forums), all to no avail. I've reinstalled linux-sound-base and the ubuntu-desktop several times.
Does someone have a "step-by-step" procedure to unscrew Audacity so that it will record like it used to or to set it up to record without having to hack the jaunty sound system every time it decides to take a hike?
I'm running ubuntu jaunty 9.04
Here's the 411 on my sound card:
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: ALC260 Analog [ALC260 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 02)
Subsystem: Hewlett-Packard Company Device 2808
Flags: bus master, fast devsel, latency 0, IRQ 21
Memory at f0500000 (64-bit, non-prefetchable) [size=16K]
Capabilities: <access denied>
Kernel driver in use: HDA Intel
Kernel modules: snd-hda-intel
Your suggestions are most appreciated...
