problems with saving
This section is now closed
Permanent link to this post Posted by lindy22 » Fri Jan 16, 2009 2:11 pm
I'm trying to work on a project now. The main problem I'm having is that one of my files (originally a .wav file, which I converted---or at least I think I did---into .mp3 version) doesn't save. The other file, though, which I'm trying to mix both together is still intact though. Hope this makes sense, lol. Any suggestions?
Thanks.
lindy22
Re: problems with saving
Permanent link to this post Posted by steve » Fri Jan 16, 2009 2:46 pm
This gets terribly confusing unless we use the correct terminology.
Audacity does not "Save" audio files - it "Saves" projects. A project consists of a small "Audacity Project File", and thousands of data files, some of which are stored in a project Data folder.
To get audio files out of Audacity you must "Export" the audio file. You can Export as WAV, MP3, or various other formats.
To get an audio file into Audacity, you can "Import" the audio file.
Return to Mac OS X
Who is online
