OK, I found the audacity Preferences file:
John/Library/Preferences/audacity Preferences
and deleted that OK but still no joy.
And I've deleted both the prefs and Audacity and reinstalled Audacity, deleted the Prefs and restarted before relaunching Audacity.
I get the "what language do you want to use" dialogue so the prefs are indeed gone, but still the problem remains. Also had a look inside the prefs file and it doesn't look like it would have any info that would affect the file saving problem anyway (not that I know much about these things).
Still cannot find audacity.cfg
Had a look at the Wiki entry on Preferences, thanks for the link.
Am thinking maybe I should try out Audactiy 1.3. Anyone know what it is like re stability etc?
Any more thoughts anyone?
Using Intel based MacBook running 10.5.6 and Audacity 1.2.5
Cheers,
John
