real_g_ranch wrote:I have installed the 1.3.5 Beta, which said it supported new vocal removal plug-in, I was not in the base product so installed the LADSPA plug-ins, still looking for it under the effects menu. Any help on find where this feature is and how to use it appreciated.
It is underneath the divider in the Effect menu "Vocal Remover (for center-panned vocals)". If you still can't see it, go
here, and click "download" at the top (to right of "Links to HEAD"). If you just get text in the browser window, right-click over the link and "Save target as" or "Save link as". Then drop the file into your Audacity Plug-Ins folder and restart Audacity.
