Pulling audio from video clip?
Audacity 1.2.x is now obsolete. Please use the current Audacity 2.x version.
Permanent link to this post Posted by shelley.marie714 » Thu Sep 25, 2008 3:25 pm
Is there any way that I can pull audio from a video clip? Not sure if it is possible, but if it is, could someone tell me how to do it? :D
shelley.marie714
Re: Pulling audio from video clip?
Permanent link to this post Posted by steve » Thu Sep 25, 2008 4:46 pm
If you mean getting the audio from a video file (such as Mpeg video, a VOB file, a WMV file, or similar) then download "SUPER" (by erightsoft) - it's a free format converter that will allow you to extract the audio digitally.
Senior Forum Staff
Permanent link to this post Posted by tarvid » Sat Sep 27, 2008 9:38 pm
File, Import, Audio, VOB file - seg faults.
The import starts, the DVD spins, the progress indicator gets about 60% complete and then Audacity dies.
tarvid@venus:~$ audacity
Segmentation fault
tarvid@venus:~$
tarvid
Permanent link to this post Posted by Des » Sun Sep 28, 2008 5:05 am
Have you got any thing like “Windows Movie Maker” or “Ulead VideoStudio” on your computer???
If not but your movie is on disk, or a file on your computer, you can play it and record the audio with audacity . You can actually record any sound you hear from your computer with audacity with a bit of a tweak. If your still stuck tell us a bit more
Des
Des
Permanent link to this post Posted by steve » Mon Sep 29, 2008 12:26 am
tarvid wrote:File, Import, Audio, VOB file - seg faults.
Audacity does not support VOB files - as it says a couple of posts earlier, if you want to use VOB files (or any other unsupported audio format) you must convert them to a supported format first.
http://audacityteam.org/wiki/index.php? ... ileFormats
Senior Forum Staff
Permanent link to this post Posted by charango » Sat Jan 24, 2009 10:28 am
I don't know if you have found the answer yet but I just installed the ffmpeg plug in and then opened an .avi file of a musical video clip and the audio was imported instantly, no sweat!
Hope this helps
charango
Permanent link to this post Posted by Al3x » Sun Jan 25, 2009 7:02 pm
stevethefiddle wrote:If you mean getting the audio from a video file (such as Mpeg video, a VOB file, a WMV file, or similar) then download "SUPER" (by erightsoft) - it's a free format converter that will allow you to extract the audio digitally.
It's the biggest pain in the ass to find the link.
Al3x
Permanent link to this post Posted by steve » Sun Jan 25, 2009 7:18 pm
charango wrote:I don't know if you have found the answer yet but I just installed the ffmpeg plug in and then opened an .avi file of a musical video clip and the audio was imported instantly, no sweat!
I think that will only work with Audacity 1.3.6 and later.
Al3x wrote:It's the biggest pain in the ass to find the link. [to download SUPER]
Yes it is, but since it's free and a very useful tool I think it's worth the effort.
Senior Forum Staff
Permanent link to this post Posted by Al3x » Sun Jan 25, 2009 7:22 pm
Thanks for the info, it's just that i'm very impatient. I'd follow a link which would take me to another link that tell how great the program is and what it's compatable with, etc etc. ;)
Al3x
Permanent link to this post Posted by kozikowski » Sun Jan 25, 2009 7:39 pm
Switch and Super are the two programs. The free one is a pain in the neck but the paid one is much easier in every way and converts more formats.
Or, yes, you can deal with ffmpeg. Both Audacities can be installed on your machine, but you can only use one at a time.
Next
Return to Windows
Who is online
Users browsing this forum: No registered users and 4 guests
