So, in a nut shell here's the problem. I like to listen to audio books on my MP3 player, but they are ALL in really small files
for each CD (1 CD contains approx 15 small mp3 files).
I've been opening all the files (Project > Import Audio), cutting and pasting the tracks into one track (Selecting the file beneath, cutting and pasting into the file above so it'll be in the correct order and not all mixed up) one at a time...
Is there a way where I can have ALL the files joined together in order without having to cut and paste all the time?
(file1,file2,file3, etc...)
I also tried selecting ALL of the files and using Quick Mix (Project > Quick Mix) but the resulting file which is supposed to be over an hour in length only turns out to be like 7 mins or so (I don't know why that is...)
Thx
Genki Dave
