Error while opening sound device - Zoom R16
Permanent link to this post Posted by factorial » Sat Sep 04, 2010 1:54 am
I just got a Zoom R16, have installed the drivers, and am attempting to use Audacity to record from it as an interface. However, whenever I hit record I get the "Error while opening sound device. Please check the input device settings and the project sample rate." message.
In Edit > Preferences > Audio I/O I have ZOOM R16_24 selected as my Recording device. I have tried 1 and 2 channels to no avail.
Under the Quality tab there, I have tried all three Default Sample Format options available to me (16, 24, 32bit), no dice. I have left the Default Sample Rate at 44100 Hz because the R16 says on the LED screen: "Sample Rate=44.1kHz"
So, is anybody else using the Zoom R16 as a multi-channel interface? What am I missing here? Thanks a lot.
factorial
Re: Error while opening sound device - Zoom R16
Permanent link to this post Posted by kozikowski » Sat Sep 04, 2010 2:41 am
Can you set the R16 for sound standard -- 44100, 16 bit, Stereo? Forget multi-track for a minute.
Set Audacity Preferences for that standard and then restart Audacity.
Oh, wait. One more step. Download and install Audacity 1.3.12.
Audacity 1.2 is no longer supported on modern computers.
So under 1.3.12, set the preferences for 44100, 16-bit, Stereo and restart. Make the mixer produce music and see if you can get Audacity to record some of it.
Return to Windows
Who is online
Users browsing this forum: No registered users and 9 guests
