Connect Audacity to Zoom R16
Permanent link to this post Posted by mardy » Mon Mar 15, 2010 9:20 am
Strictly Amateur......have dowloaded Audacity and have it working (XP Home) and starting to understand it.....would appreciate help in connecting to R 16......downloaded drivers but cant follow further instructions.....Thanks..
mardy
Re: Connect Audacity to Zoom R16
Permanent link to this post Posted by kozikowski » Mon Mar 15, 2010 3:15 pm
This device is a controller or control surface for a Digital Audio Workstation and unless you already have a DAW (you'll know because of the amount of money it cost), that part isn't going to do anything.
It's very difficult to get Audacity to record multi-track live -- particularly if the device uses ASIO software which many good audio devices do. Audacity doesn't directly support ASIO.
So that leaves transferring files from the SD memory card. That you can probably do. Does the device mount in Windows via USB so you can see the memory card, or do you have to take the card out and put it in a memory card reader on the computer?
Permanent link to this post Posted by whomper » Mon Mar 15, 2010 6:11 pm
mardy wrote:Strictly Amateur......have dowloaded Audacity and have it working (XP Home) and starting to understand it.....would appreciate help in connecting to R 16......downloaded drivers but cant follow further instructions.....Thanks..
dont!
record on the r16 first
drag and drop a wav file to the pc
then open that file with audacity
faster easier better cheaper than trying to go direct from mike to audacity via r16
whomper
Probationer (now banned)
Permanent link to this post Posted by mardy » Mon Mar 15, 2010 8:08 pm
Koz & Whomper Thank you both for reply.......Straight and simple answers.....have been transferring files to Audacity and experimenting....will now read more of the instructions....will try card reader,but just as easy to put card in pc....has capacity for several types of cards.......Thanks again...mardy
mardy
Return to Windows
Who is online
Users browsing this forum: No registered users and 4 guests
