Posted by bassofone » Fri Jan 25, 2008 4:17 am
I'm getting the same error message(running Vista, Acer 3100 w/ AMD dual core 4400, recording from Minidisc plugged into mic in of Realtek sound card)--checked settings(sample rate,devices enabled) in preference menu, checked sound card settings, all as it should be, but error message persists. Audacity was working fine during my initial attempt, until it crashed, after which I downloaded the recovery utility, which Vista didn't seem to like. The feeling was apparently mutual, as the utility "stored" the recovered files in a nonexistent folder. After 2 recovery attempts, I let Audacity delete the temp files from the prompt upon opening, and uninstalled the recovery utility. When I attempted to record again, hello pesky error message. So--what now?
OK, I'll answer my own question--in my case, it was resolved by switching the "recording device" setting to aux, instead of using stereo mix (which I'd swear was the setting when it worked before, but what do I know?).
Now Audacity seems to have changed its mind and likes stereo mix again. No more trying to be Mr. Smart Guy for me....
