Selected part of track, cannot cut, copy, trim, etc.
Audacity 1.2.x is now obsolete. Please use the current Audacity 2.x version.
Permanent link to this post Posted by xgravity23 » Tue Aug 25, 2009 1:36 pm
I am having a really weird problem, but I'm new to Audacity, so it could just be that. Let me try to describe what happens.
When I select part of track (using the mouse to click and drag), I lose most editing options in the Edit menu. All options are grayed out except those that are available when you have NO tracks open at all, when you start Audacity fresh. The only way around this that I have found is to save after each successful edit, and restart. Sometimes Audacity lets me edit for a longer period of time, and sometimes not at all. Very frustrating.
Can anyone help? Do I need to provide more detail?
Thanks in advance.
xgravity23
Re: Selected part of track, cannot cut, copy, trim, etc.
Permanent link to this post Posted by kozikowski » Tue Aug 25, 2009 5:08 pm
Let's take the obvious ones first. If you start a fresh Audacity, does it act OK if you try to edit this 6 second sound clip?
http://www.kozco.com/tech/piano2.wav
Permanent link to this post Posted by xgravity23 » Tue Aug 25, 2009 7:41 pm
Yes, it seems to work just fine with that clip.
BTW: All clips I'm trying to edit were created with Audacity.
xgravity23
Permanent link to this post Posted by xgravity23 » Wed Sep 02, 2009 12:04 am
Okay, the problem happens if I have just opened a file and after I...
    *adjust the decibels
    *silence a selection
    *delete a selection
xgravity23
Permanent link to this post Posted by steve » Wed Sep 02, 2009 12:37 pm
Could you give the exact "clicks" and button presses for those steps. (There are several different ways of doing each of those actions).
Senior Forum Staff
Permanent link to this post Posted by xgravity23 » Thu Sep 03, 2009 7:06 pm
To adjust the gain, I
* open the file
* push the play button
* slide the gain slider on the left side of the track
To silence a selection, I
* open the file
* scroll to the selection using the scroll bar on the bottom of the Audacity window
* use the mouse to select part of the track,
* click the silence button on the toolbar (looks kind of like this, if you use your imagination: w|-|w )
To delete a selection, I
* follow the same first three steps from "To silence a selection" above, then
* click Edit > Delete in the menu
Thanks in advance for you help!
xgravity23
Permanent link to this post Posted by steve » Fri Sep 04, 2009 3:04 am
You know, I've been using Audacity all this time and I never noticed that you could silence a section with the w|-|w thing :D
Well I've tried all those things and I can't reproduce the problem, but I think I'm using a much more recent version of Audacity. I'm using Audacity 1.3.9
Try upgrading to 1.3.9 and see if that fixes the problem. (the 1.2 version is really old now and can have some very strange problems on modern machines).
Senior Forum Staff
Permanent link to this post Posted by waxcylinder » Fri Sep 04, 2009 2:12 pm
stevethefiddle wrote:You know, I've been using Audacity all this time and I never noticed that you could silence a section with the w|-|w thing :D
Hey, me too - and neither did I. And the -|w|- looks like it could be useful too :)
Though actually both of them are doable much quicker with k/b shortcuts:
Trim: -|w|- is CTRL+T
Silence: w|-|w is CTRL+L
* * * * * FAQ * * * * * Tutorials * * * * * Tips * * * * * Audacity 2.0 Manual * * * * * Audacity wiki * * * * *
waxcylinder
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 5 guests
