Remove the "Fade In" or "Fade Out" effect
Permanent link to this post Posted by audj » Mon Aug 27, 2007 2:03 am
Hi,
Does anyone know a way to remove the fade in or out effect once the file is saved and it's too late to "undo" ?
I tried the "Normalize" effect but that made it too loud...For now I'll just re-import that piece and start again.
Thanks,
Audj
audj
Re: Remove the "Fade In" or "Fade Out" effect
Permanent link to this post Posted by alatham » Mon Aug 27, 2007 6:31 pm
It's not possible once you've lost the ability to undo.
alatham
Permanent link to this post Posted by audj » Fri Aug 31, 2007 1:11 am
Thank for confirming that...Audj
audj
Permanent link to this post Posted by wildshovel » Sun Oct 21, 2007 11:26 am
I do wonder though...
What if you had to reverse a poorly done fade on a track for which you did not have the original?
For example, I have this audio from an amateur video of a band performance. The person who mastered the video started a fade way too early, something like 2-3 minutes before the end. I would like to fix this, but I don't have access to original unfaded version. What I am thinking is that I would reverse the fade temporarily, and then refade, starting 30 seconds before the end. Shouldn't be too bad, as the noisiest part I'd be fading out anyway.
Is there a way to gradually increase the volume a selected section of a waveform? Ideally, It would be something like Audacity's graphical fade in, except that you could start at 100% volume and go up from there.
wildshovel
Permanent link to this post Posted by alatham » Mon Oct 22, 2007 10:21 pm
wildshovel, you can use the Envelope tool to do that sort of thing, but the noise floor is going to rise along with the "un-fade." It won't sound pretty unless if was recorded particularly cleanly.
alatham
Permanent link to this post Posted by wildshovel » Sun May 18, 2008 9:32 pm
Thanks, alatham -- I'll give the envelope tool a try...
-WS
wildshovel
Return to General Feedback and Discussion
Who is online
Users browsing this forum: No registered users and 5 guests
