If you want to know about new features in releases I suggest you sign up to our announcements list at the bottom of http://audacityteam.org then look in the advertised Release Notes for each new version.
Can someone compile channel mapping for me?
I’ll pay.
Garage band is driving me nuts. Basic cut & paste etc etc can’'t find how to do
Audacity is much nicer to use
Are you sure that patch does what you want? Read its description carefully. It was not a finished patch. You will have to quit Audacity then modify audacity.cfg in TextEdit using the correct syntax to set the channel mapping.
If the patch no longer compiles with current Audacity then it will be time consuming for someone who regularly compiles Audacity to go back to Audacity at the time of the patch. To begin with they will have to recompile the previously supported version of wxWidgets.
You may be better to send a PM to the developer who wrote the patch and encourage him to resume work on it.
Dear Gale
Thanks for your reply
I’ve no idea what you are saying as I’m not technical.
What patch are you referring to ?
I’m not aware of a patch to make input mapping possible on the Mac.
Not sure I even know what a patch is !
& I don’t know a developer.
On Linux the Jack Audio System can be used to map inputs and outputs. There are a couple of versions of Jack Audio System for mac, but from a quick Google search they look to be experimental and may not work on Sierra.
Another possibility, it might be possible to configure Soundflower to provide input mapping.
(Windows has the biggest problem as input/output mapping is usually done with ASIO, but Audacity cannot be shipped with ASIO support enabled due to licensing restrictions.)
Every sound card that I’ve used with Audacity defaults to channels 1 and 2. It’s a mystery to me why your set-up does not do that, but I don’t have a firewire Focusrite sound card to test.
Hi Steve
You mention -‘‘Every sound card that I’ve used with Audacity defaults to channels 1 and 2. It’s a mystery to me why your set-up does not do that, but I don’t have a firewire Focusrite sound card to test.’’
A] Is this with Mac ?
B] Is this when using SPDIF into the cards ?
C] If so then please can you let me know make & models of cards that will route spdif input to CH 1&2 on Audacity
So in a nutshell Audacity is not usable on main channels [1&2] with spdif inputs !
This is a big drawback.
Such a shame as I really like Audacity
How much work would be involved to make inputs mappable ?
I’m not any kind of developer BTW.
However I’d be prepared to pay a developer to sort this out
For a price within reason of course
Any takers ?
Can you attach the contents of Help > Audio Device Info… top right of Audacity then we can see what devices Audacity sees. Please see how to attach files to forum posts.
Have you tried in Audio MIDI Setup making a two channel aggregate device with your S/PDIF channels 5 and 6 as channels 1 and 2? You could then set Audacity to record from that aggregate device.
